VW Golf 5 MFD 2 navigation
oddnor
Bericht door oddnor »
Hello!
I'm a new member of this site, and from Drammen in Norway so I can only write in english. ( hope it's ok)
I have some questions about how to connect video ore other dings to the system, so I can hold the kids i the
back seat ocupied.
Also use the system and it's options
Can audio(radio) be in use when the navigation is in use.
Also can the cd be used with navigation (music/map)
How can I finde the rev code ore letter
What extras do I need
Regards
Odd
I'm sorry to disappoint you but with the MFD2 sytem you have you cannot do any of the things you mention.
You can play video if you have a videoplayer connected. You can hear audio only on the B or C series when not navigating and you cannot see video in the back while navigating
It is in fact a less usefull system for the things you want.
The only thing you can do is listen to the radio when navigating
oddnor
Hi !
Thanks fore the answer,
How can I find the type letter code if it's a B ore C ore
Fore use the options in my first topic witch type ore other navi system to use
Thanks
Odd
The B type can play audio cd's, the C type has aluminium knobs and buttons
    Weergaves: 1219
  • VDO / Mark III navigation system retrofit kit - change language problem
    door glm2006ITALY » 07 okt 2017 22:25 » in Vaste VDO-Dayton systemen
    Weergaves: 663
    Weergaves: 1001
  • RNS510 in vw Golf 6
    Weergaves: 734
    Weergaves: 593
