[INFO] MI2200 - Multimedia module
VDO MI2200
MI 2200 Highlights
Enables stand-alone use of 2 VDO Dayton Monitors
Automatic and Manual Source Selection
IR Remote Control
Various audio output
Input for up to 4 Sources
* VDO Dayton Navigation System
* VDO Dayton Reversing Camera Set
* Two Universal AV Input
Integrated power supply for Reversing Camera
Options
In/output connector terminal RST 5400 for interior integration
Reversing Camera
Video components (e.g. TV Tuner, DVD Player)
2nd Remote Control
Technical Data
Operating voltage: 10.5V – 15.6V, negative ground
Power consumption: typ. 2A / 3.2A (1/2 monitors)
Operating temp. range: -20°C to +70°C
Video in/out (AV1/2): 1Vpp / 75 Ohm
Audio in (AV1/2): 2Vpp / 20 kOhm
Audio 1 RCA out: 1.5Vpp / 10 kOhm
Req. headphone impedance: min. 32 Ohm (for use with RST 5400)
Dimensions (w x d x h): 170 x 110 x 40 mm
Weight: ca. 350 gr
    Weergaves: 813
    Weergaves: 1786
    Weergaves: 1250
    Weergaves: 696
