Allen,
Ik heb erg moeten zoeken in de diverse forums, maar ik heb ze...de uitleg over de aansluitingen van mijn MFD 2. Omdat er wellicht andere mensen op zoek zijn naar hetzelfde, hierbij de info:
Multiple connector 3, eightfold, for loudspeaker exits
Referencist the radio navigation system in the vehicle additionally equipped with an amplifier, then are used these loudspeaker exits as input signals for the amplifier.
1 - Loudspeaker, plus, back right
2 - Loudspeaker, plus, front right
3 - Loudspeaker, plus, ront left
4 - Loudspeaker, plus, rear left
5 - Loudspeaker, minus, back right
6 - Loudspeaker, minus, front right
7 - Loudspeaker, minus, front left
8 - Loudspeaker, minus, rear left
Multiple connector 4, eightfold, for voltage supply lines and CAN bus
9 - CAN bus High
10 - CAN bus Low
11 - Radio audio muting (with telephone enterprise)
12 - Voltage supply, minus, clamp 31
13 - Connection for ignition key-steered switching (s-contact on and off)
14 - Contact for alarm installation (optional)
15 - Voltage supply, plus, clamp 30
16 - Control signal for theft safety device, SAFE
Multiple connector 5, twelvefold, for telefonsignale and preamplifier output signals
1 - External audio entrance left
2 - External audio entrance mass
3 - LINE Out left
4 - does not occupy
5 - Driver's instruction sheet Nf +
6 - Telephone audio input signal, TEL-
7 - External audio entrance right
8 - LINE Out, mass
9 - LINE Out right
10 - does not occupy
11 - Driver's instruction sheet Nf -
12 - Telephone audio input signal, TEL+
Multiple connector 6, twelvefold, for CD changer switch control and CD audio input signals
1 - Audio signal output for headphones, right, plus
2 - CD changer switch, left and right channel, mass
3 - Audio signal output for headphone, minus
4 - CD changer switch, voltage supply, plus, clamp 30
5 - Audio signal output for headphones, left, plus
6 - CD changer switch, DATA OUT (data exchange to the CD changer from the radio navigation system to the CD change-over switch)
7 - does not occupy
8 - CD changer switch, left channel, CD/L
9 - CD changer switch, right channel, CD/R
10 - CD changer switch, control signal (switched live)
11 - CD changer switch, DATA IN (data exchange to the CD changer from the CD change-over switch to the radio navigation system)
12 - CD changer switch, CLOCK (internal inspection report for the monitoring of data flow)
Het enige wat ik niet heb kunnen vinden is de volledige uitleg over de AUX ingang...wellicht heeft iemand die.
MFD 2 CD: Informatie over aansluitingen
remondepemon
Nog 32 jaar tot mijn pensioen...
Seat Leon + MFD 2 CD
Weergaves: 698
Weergaves: 782
Weergaves: 592
