[INFO] MS3200/03 - Standalone monochrome navigatie met C-IQ
VDO MS 3200 /03
Deze set bestaat uit :
PC3200 Navigatie computer
MM3000 /03 Monitor 3,6" zwart
RC5400 /01 Afstansbediening zwart
Navigation
Comprehensive Pictogram- and Voice Guidance
9 Languages with 21 Voices
Route Criteria:
- Fast Route, Short Route
- Prefer Motorways, Avoid Motorways
- In Combination with Avoid Toll Roads
- Optimized for Traffic Situation
Calculation Alternative Route
Traffic Information (with optional TMC Receiver):
- Graphical Information of the Congestion Source
- Traffic Information on Route and sorted on Actual Position or on Destination Control
- Detailed Event Information
- Detour Calculation incl. Info on Additional Time and Length
- TMC Info available without Guidance
Address Book for approx. 200 Entries (Categories: Home, Work, Business, Private)
Last Destinations: 20 Entries
Via Points: 25
Trip Computer:
- Current/Average Speed
- Travel Time/Distance (resetable)
- Programmable Speed Warning
- Maximum Speed
Selectable Guiding Screen (with Time, Travel Distance, Travel Time, Estimated Time of Arrival)
Programmable Remote Control
Upside Down Mode: The displayed picture can be turned 180° (upside down) for sealing mounting
Easy detachable Monitor for Theft Protection
Easy to operate (self explaining menu)
Speed Dependent Volume Control (SDVC)
Demo-Mode, blocking of CD Eject Button possible
Technical Data
Dimensions (w x h x d): DIN Housing,
180 x 51 x 160 mm
RMS Power:
4 x 22 Watts at 10% THD (DIN 45324) and 14,4V
Interfaces
- RS 232, D2B, I2C, I2S
- Reverse Gear Signal
- Audio Output 5W/4Ohm (External Loudspeaker)
- GPS Antenna (SMB, 5V)
Sensors:
- 8-Channel GPS Receiver
- Gyroscope
- Interface for Speed Signal
Power Supply:
- 12 V DC, – at GND
- Voltage Range: +9V ... +16 V
- Current Consumption: about 1 A
(about 0.1 A in off state)
Temperature Range: -20° C ... +65° C
Processor:
32-bit MIPS ASIC @ 108,2 MHz
Memory:
32 MB NAND Flash/32 MB SD RAM
Drive: CDM-M3 CD-ROM anti scratch drive
Monitor
White/Orange Backlight via LED
64 x 120 dots Resolution
Automatic Display Brightness Control
Horizontal and Vertical Swivelling
B2B Bus Connection
Easy Detachable Display
110 x 81 x 53 mm
Remote Control
IR Remote Control (16 keys)
Direct Access to Main Functions
(incl. programmable Favourite Button)
    Weergaves: 1750
    Weergaves: 1233
    Weergaves: 1589
    Weergaves: 3516
    Weergaves: 1369
    Weergaves: 698
  • Problemen met mfd2
    Weergaves: 1099
