[INFO] WT5100 - Koptelefoon zender
VDO WT 5100 - Koptelefoon zender
Features
High Sound Quality
2-Channel Stereo Transmission (enables use of 2 independent AV Sources)
Auto Power-On/Off (through ignition or trigger output)
Small Dimensions
Simple Installation
Technical Data
Operating Voltage: 9.5 to 15.6 V=
Audio Transmission Channel A: 2.3 MHz
Audio Transmission Channel B: 2.8 MHz
Free Air Transmission Range: min. 5 m @ ± 20° h/v
Cable Length: 1.5 m for +12V ACC and GND 20 cm for RCA
Fuse: 500mA 5 x 20 mm
Storage and Operating Temperatur:
min. -10°C
max. +70°C
Weight: ca. 220 g
Package Content
1 x WT 5100 Unit
1 x Installation Clamp
1 x Installation Screw
1 x User Manual (GB, FR, DE, NL, IT, DK, ES)
1 x Individual Carton Box
    Weergaves: 696
