[INFO] AVH-P6500DVD - AV headunit
Pioneer AVH P6500DVD DVD AV Headunit
DVD AV Headunit
When you are ready for in-car audiovisual, then the AVH-P6500DVD DVD AV headunit is a must. Tailored to Pioneer’s new DVD Cyber Navi software, this component is actually a complete control centre with a built-in AV Master, digital AM/FM tuner and DVD player. The motorised, high-quality touch panel display lets you manage the entire system from audio and video settings to navigation commands with a simple tap on the screen. The easy-tounderstand Graphical User Interface guides you through the most advanced settings step by step.
The AVH-P6500DVD is compatible with the latest digitally encoded discs: DVD-Video, DVD-R/RW, VideoCD, CD-R/RW and MP3. Connect the DEQ-P7000 to your AVH-P6500DVD and transform your car into a multi-channel surround “cinema on wheels”! The handy Dual Zone function splits your entertainment space in two: you can listen to music up front while your rear seat passengers enjoy a different AV source, like a DVD film.
Solid state sound is guaranteed with Pioneer’s high-quality MOSFET 50 amplifier and you can hook up external amps on the 3 Hi-Volt pre-outs or add a DAB tuner, TV tuner or multi-CD player to complete your in-car system. For extra convenience: the 10-character sub-display shows the audio-visual status when the touch panel display is closed.
Key features AVH-P6500DVD
Fully Motorised Touch Panel Display
Dual Button illumination (green/red)
MP3 CD Playback
DVD-Video, DVD-R/RW compatible
Dual zone operation with front Video and rear AV output
Back-up camera input
D4Q Digital AM/FM tuner
3-channel Hi-Volt (4V) Pre-Outs (F+R+SW)
General AVH-P6500DVD
Amplifier MOSFET 50W x 4
Equaliser EEQ+ Equaliser with HPF, LPF & SFEQ
Built-in AM/FM RDS Tuner D4Q (ARC 5)
DVD Capabilities
  • * DVD-Video/Video CD/MP3 CD player
    * Built-in Linear PCM/DTS/Dolby Digital decoder
    * DVD-Video/Video CD Playback with Direct Search Chapter/Track, Next/Previous Chapter/Track, Fast forward/reverse, Pause, Track/Chapter Repeat, Condition Memory (30 discs), Play back Control (Video CD only), Direct Search Title/Group, Time Direct Search, Scan, Digital Direct
CD Capabilities
  • * CD Playback with Track Scan/Pause/Repeat, Random Play, CD Text, List Search
    * 96KHz/24-bit DAC
    * 24-bit D/A Converter
    * Fast forward/reverse
    * Track Search/Scan/Repeat
    * Track/Manual search
    * Last position memory (for CD function only)
Source Control MCD, SCD, TV DVD, DAB Tuner
Control via front panel buttons or Remote
Voice Guidance When connected to Pioneer Navigation System
Display type Wide Screen TFT active matrix LCD Color Display
Touch Panel Operation Yes
Display size 6,5 Inch
Screen Coating High quality anti-Glare, Low-Reflection coating
Installation possibilities In-Dash
Fully motorised display with auto dimmer with free adjustable viewing angle (50 - 110°)
Front panel Removable with safety warning beep
Selectable wide screen modes Just / Full / Cinema / Zoom / Normal
Input for rear camera Yes
Rear camera switching Yes
Dual Button illumination Yes (green/red)
Remote Control Standard
D/A Convertor 24-bit
DVD - R/RW and CD - R/RW Playback Yes
Built-in MPEG 2/1 decoder Yes
DVD video player Yes
Region number 2
Connections AVH-P6500DVD
AV Output 3 Hi-Volt (4V) Pre-outs (F+R+SW)
AV inputs 1 RCA
AV Bus Input Yes
RGB input for AV Master or Navigation System yes
IP Bus input/output Yes
DVD video output Yes
    Weergaves: 791
    Weergaves: 696
