[INFO] DCM6500 - Dakmonitor
VDO DCM 6500 - Dakmonitor
Features
8" Overhead Monitor with integrated DVD Player
All-In-One Automotive multimedia system
16:9 Widescreen Display
Integrated DVD player for DVD, (S)VCD, JPEG, MP3, CD-A
On-Screen-Display (OSD) Menu
Infrared Headphone Transmitter (Headphone package as accessory)
Output for 2 wired Headphones (with individual volume control)
Input for 2 AV sources (1 on front for quick access)
AV Output for 2nd monitor and / or Audio System
On-unit as well as remote operation possible
2 integrated Dome Lights
Universal Installation Plate and Trim Ring included
Technical Data
Size/Format: 8", 16:9
Resolution: 400 x 234 pixels
Max. brightness: 400 cd/m≈
Antiglare Coating
Automatic PAL/NTSC switch
Automatic 50/60 Hz switch
Auto power-on after fold-down
Integrated drive compatible to DVD (region code 2), (S)VCD, JPEG, MP3, CD-A
Operating voltage: 10.5V – 15.6V, negative ground
Power consumption: typical 1.5 A/(3 A max.)
Video in/output (AV 1/2): 1 Vpp
Audio input (AV 1/2): 2 Vpp/20 KOhm
Video output: 1 Vpp
Audio output: 1.5 V/10 KOhm
Req. headphone impedance: min. 32 Ohm
Dimensions (W x D x H mm): 170 x 350 x 60
Weight: ca. 2.250 g
Options
Multiple Input/Output possibilities
Connection of headphones via cable
Connection of headphones via Infrared
Package Content
1 x DOM 6500 Unit
1 x Power Cable (5 m)
1 x Mounting Plate
1 x Set of Screws
1 x Rubber trim ring
1 x Installation and Operation Manual (GB, FR, DE, NL, IT, DK, ES)
1 x Individual Carton Box
    Weergaves: 696
