[INFO] IVMR-9002 - 9.0" plafondmonitor
Blaupunkt IVMR 9002 - 9.0" Wide Screen Overhead Monitor
TFT-LCD Size (Diagonal) 9.0" (22.7cm)
Aspect Ratio 16:9
Application Overhead
Product Plan / Sales Start Nov-03
Features
Power On/Off Yes
Volume Up/Down Yes
Menu Button Yes
Contrast Control Yes
Brightness Control Yes
Reverse Screen Yes
On Screen Display (OSD) Yes
Remote Control Yes
Speaker Built-in
Power Indicator Blue LED ON/OFF
Audio Output RCA
Additional Video input RCA
IR sensor for Remote (angle) Yes (+/- 30 degrees)
IR transmitter of IR headphone (Overhead Only) Min.8 IR Bulb
IR Headphone transmitter angle +/- 80 degrees
Speaker Built-in
5 buttons(Ch, Menu, Down, Up, PWR) Yes
Open to Close 0 to 180 degrees
LCD Pivot Location Back-end
Dome Light Yes
Housing Color Natural Tan
Main Menu / ZOOM
FULL to display 16:9 screen
ZOOM1 to display 4:3 aspect-ratio
ZOOM-WIDE1 vertically extension. Zoom factor =8/7
Technical data
Screen Size (Diagonal) 9.0" (22.7 cm)
Pixel Format (pixels) 480(W) x 3(RGB) x 234(H)
Aspect Ratio 16:9
Contrast Ratio 250:1
Contrast Ratio (minimum) 100:1
Signal System NTSC/PAL (auto switch)
Power Supply 10.0V…16.0V
Video input level Composite Video, 0.7Vpp - 2.0Vpp, 75 Ohm
Audio input level 0-0.3 Vrms
Speaker Output 1 Watt, 280 Hz - 20 kHz
Headphone Output 40 dB gain @ 16 Ohms, 20 Hz - 20 kHz, THD 1%
Operating Temp 0 to + 60 Celsius
Storage Temp 6-30 to +80 Celsius
Electrical power consumption 10.0V…16.0V
Luminance, white / Backlight Life Time 400 cd/m2 / min. 10k hours
Display Method TFT Active Matrix LCD
Back Light Cold Cathode Filament Tube
Viewing Area (W x H, mm) 198.0 x 111.74
Viewing angle left-right 65/65
Viewing angle top-bottom 50/65
Brightness (minimum) 300 cd/m2
Monitor Dimension (W x H x D, in) TBD
Monitor Dimension (W x H x D, mm) 165.0 x 122.0 x 26.7
Monitor weight (g) TBD
Connector 13 Pin DIN Cable
High Temp & High Humidity TBD
Pixel Pitch (W x H, mm) 0.4125 x 0.4775
Number of Color Full Color
Response Time (msec) 33
Swivel angle left-right 0+/- 45 degrees
TFT-LCD Dimension (mm) 210.0 x 126.4 x 6.7
Power Consumption (W) 3.2
TFT -LCD Weight (g) 250
Thickness of the chassis (Overhead Only) 35mm
Thickness of monitor 30mm
Accessories
Mounting Kit Yes (Overhead Shroud Included)
Extension Cable (5m, 13 PIN DIN) Yes
DIN to RCA Cable with PWR/GND Yes
Remote Control with battery Yes
Headphone N/A
Manual Yes
Monitor Release Key (Headrest Mon. Only) N/A
Mounting Screws Yes
Metal plate for fixation Yes
    Weergaves: 696
