Mijn nuvi garmin 1490T is er mee opgehouden.
Nu heb ik hetzelfde type hier nog liggen.
Bestaat er de mogelijkheid om alle gegevens (adressenbestand in favorieten en recent gevonden)over te zetten van de ene
garmin naar de andere?
Zou me zeer veel werk besparen, er staan toch wel een paar honderd adressen in
Alvast bedankt voor jullie reactie
Groetjes Ellly
gegevens overzetten van de ene garmin naar de andere
girlfromdutch
Mr.BS
Re: gegevens overzetten van de ene garmin naar de andere
Hoi Elly,
Het zou in principe moeten lukken op de volgende manier:
Instructions for a PC:
1. Connect the Garmin device to a computer using a data transfer USB cable.
2. Double-click on My Computer or Computer.
3. Right-click on the Garmin device drive and select Open.
4. Locate and double-click the GPX Folder.
* Some devices require you to open the folder named "Garmin" or "Internal Storage" first, then the GPX Folder
5. Right-click and copy the Current.gpx file.
6. Locate your computer's Desktop.
7. Right-click and select Paste to save the Current.gpx file onto your Desktop.
To send the file back to the GPS, please follow the steps below:
1. Right-click on the Current.gpx file on your Desktop and select Rename.
2. Name the file Current1.gpx and then press Enter.
3. Right-click on the Current1.gpx file and select Copy.
4. Connect your device to your computer.
5. Double-click on My Computer or Computer.
6. Right-click on the Garmin device drive and select Open.
7. Locate and double-click the GPX Folder. (On some devices you may need to open the Garmin Folder first then open the GPX Folder)
8. Right-click and select Paste.
9. Disconnect your device from your computer and allow it to boot up. Some devices do not automatically boot up. If your device does not automatically boot up, turn the device on as normal.
Your favorites will now be restored on your device. To transfer the saved Favorites from one mass storage device to another, connect the new device to the computer in Step 4 and then follow the remainder of the steps.
girlfromdutch
Dank je wel voor je snelle reactie
Ik ga het morgen uitproberen.
girlfromdutch
En het werktgirlfromdutch schreef:Dank je wel voor je snelle reactie
Bedankt scheelt weer een heleboel adressen ingeven
ottobw
Als je naar een ander type Garmin overgaat (bv van de 1490 naar de Drive 51), werkt het kopiëren van het bestand Current.gpx naar de map GPX niet. Maar met behulp van Kladblok (of Notepad of 'n andere simpele text editor) kun je toch je favorieten doorschuiven naar je nieuwe navigator.
Bijvoorbeeld:
In een nieuwe Drive 51 staat in de map GPX het bestand Current.gpx met de gegevens van een paar GARMIN kantoren op verschillende continenten. Het enige wat je hoeft te doen is deze gegevens vervangen door je eigen gegevens.
Dat kan als volgt:
Hang je oude navigator aan je computer.
Maak een kopie van het bestand Current.gpx uit de map GPX van je oude navigator naar je computer.
Open deze kopie met kladblok of notepad of een andere simpele text editor.
Koppel de oude navigator af en koppel dan de nieuwe navigator aan je computer.
Maak voor de zekerheid op je nieuwe navigator een kopie van het bestand Current.gpx in de map GPX.
Open de Current.gpx in de map GPX op de nieuwe navigator met kladblok of notepad of een andere simpele text editor.
Het eerste deel van elk bestand opent met info over de navigator. Deze info loopt tot en met de tekst </metadata>
Selecteer de tekst tot en met </metadata> in de kopie van het bestand van de OUDE navigator en verwijder deze tekst.
Selecteer en kopiëer nu de tekst tot en met </metadata> in de Current.gpx van je NIEUWE navigator.
Plak deze tekst bovenin het bestand van je OUDE navigator en sla dit bestand op op je computer.
Kopiëer dit gewijzigde bestand van je OUDE navigator naar de map GPX van je NIEUWE navigator.
Koppel de nieuwe navigator af van je computer en start 'm op.
Je kunt nu op je nieuwe navigator beschikken over je favorieten.
Bijvoorbeeld:
Dat kan als volgt:
Mazurka
Zou deze post nog zin hebben na ruim 7 jaarottobw schreef:Als je naar een ander type Garmin overgaat (bv van de 1490 naar de Drive 51), werkt het kopiëren van het bestand Current.gpx naar de map GPX niet. Maar met behulp van Kladblok (of Notepad of 'n andere simpele text editor) kun je toch je favorieten doorschuiven naar je nieuwe navigator.
Bijvoorbeeld:
Dat kan als volgt:
Garmin Etrex Touch 35 ruilen voor Garmin Edge
door Tomwes321 » 04 apr 2022 19:37 » in Ruilen / Gratis op te halen -
Weergaves: 670
Weergaves: 701
Weergaves: 1492
Reacties: 7
Weergaves: 2890
Weergaves: 852
Weergaves: 609
Reacties: 5
Weergaves: 1556
