Nieuwe navigatie firmware voor dnx8220bt/7220/5220: 2.40
Piet22
Bericht door Piet22 »
Zie:
http://www.kenwood.nl/up_2_date/car/multimedia/dnx8220
Of:
http://www.kenwood.be/nl/support/downlo ... iecomputer
Change History
Changes made from version 2.30 to 2.40:
Fixed a problem with elevation basemap shading.
Fixed a problem with reading files from an SD card.
Changes made from version 2.20 to 2.30:
Fixed a problem that would display the unit id as a negative number when updating maps.
Fixed a problem that could interfere with a map update if a pop-up message occurred.
Fixed a translation problem with British English
Fixed a problem with the elevation basemap not drawing in 2d mode.
Removed a message that may pop-up if WAAS was enabled.
Added support to correct problem if 'Maps are locked' message appears.
Changes made from version 2.10 to 2.20:
Pressing on the next turn distance and time on a custom map tab will repeat the next turn instruction.
Added code to prevent the loss of map unlock codes.
    Weergaves: 750
    Weergaves: 2387
    Weergaves: 973
  • nieuwe kaarten 965.xxxx.
    Weergaves: 1077
  • Nieuwe dvd voor NVE-N099P
    Weergaves: 2126
  • nieuwe kaarten 985.xxxx
    door japie57 » 17 feb 2017 13:15 » in TomTom
    Weergaves: 1915
  • Nieuwe kaarten 990.xxx
    door japie57 » 19 mei 2017 13:11 » in TomTom
    Weergaves: 2678
Terug naar “Kenwood”
