I apologize for posting in English, but I don't know Dutch, and this seems to be the best forum for navigation systems
I have the vdo Dayton/Philips/Audiovox PC 5000 navigation system. A petty thief recently stole the monitor from my car. I guess the joke is on him, as, without the PC 5000 system, the monitor is worthless. Nonetheless, I need to find a replacement monitor. I see that I have some options:
I can find a new vdo monitor (expensive). This would be the MM 5510, or the M5010 monitor.
I can find a secondhand video monitor (less expensive). This would be the predecessor of the MM 5510 or the MM 5010 monitor. But perhaps a previous generation. As long as the connector is the same I don't care
I can buy a cheap, generic LCD monitor, with an RCA input jack, along with an adapter to convert from the vdo Dayton connector to an RCA plug.. I see on the Internet that vdo sells a connection Kit for the vdo Dayton navigation commuter to plug into an MR 6000 monitor or Clarion monitor.
So, I have a few questions:
is there a resource for secondhand monitors that accept the vdo connector? It does not matter to me what the monitor has for a brand on the front. I have looked on eBay, but the problem is that the same monitor was sold under different brand names. Vdo, Philips, Mannesmann, and Audiovox all were selling the same monitor, but under different brand names in different model numbers. As the person selling the monitor on eBay is often unfamiliar with what he's selling, sometimes the descriptions are not entirely reliable.
Alternatively, is there somewhere where I can purchase the vdo part MA 2610, which I understand to be an adapter between the output on the vdo Dayton cable and an RCA plug on the other side. Is there some place that I can confirm that the output on this adapter is indeed an RCA jack?
Many thanks for your help.
Ted
VDO dayton monitor
tedpnyc
The only monitor that will properly function with the said system is an VDO monitor and at the same time this is the only brand of monitors that carries this type connnector. Monitors of thesi type are regulrly being advertised or offered even even here in the "Te koop aangeboden" part of this forum.
The other susggestion to use an ordinary LCD monitor in combination with an interface is cumbersome, expensive and disappointing in resolution.
In addition: the MA 2610 is the interface between the VDO computer and some Clarion Headunits. It is not a generic interface, so cannot be used to other monitors.
Regards,
Regards,
vriensr
Beste JW,
Ik wil een Clarion monitor VRX928RVD aansluiten op een VDO Dayton PC5200.
De Clarion werkt prima op een VDO Dayton MS5500, maar met de PC5200 vervormt het beeld.
Kun je aangeven of daar een oplossing voor bestaat?
Bijvoorbeeld gebruik van MA2600 (eventueel met modificatie) of de MA2610?
Bij voorbaat dank voor je antwoord.
Met vriendelijke groet, Rob
Er is een oplossing:
De stekker naar de monitor vanuit de pc openmaken en pootje 15 met pootje 16 doorverbinden. Het slechte beeld ontstaat doordat de spanning (12v) op pootje 15 ontbreekt. Die is wel te vinden op pootje 16. Dus vandaar het doorverbinden.
En uiteraard de MA2600 gebruiken als interface.
Werkt 100%.
Werkt 100%.
vriensr
Bedankt voor je snelle reaktie. Dat heeft me enorm geholpen.
Is er toevallg iemand die een MA2600 te koop heeft?
Groeten, Rob
Je hebt het over pootje 15/16, bedoel je om die binnenin de PC5200 te modificeren? Of in de kabel? Of in de MA2600? Kun je dat misschien voor me verduidelijken?Gene schreef:De stekker naar de monitor vanuit de pc openmaken en pootje 15 met pootje 16 doorverbinden.
Groeten, Rob
Die PC 5500 werkt met de Clarion zónder gebruik van een MA 2600? Heb je dat getest?vriensr schreef:Beste JW,
En hoe is 'ie aangesloten dan?
vriensr
Hoi JW,
Je hebt gelijk, ik was zelf ook al tot de conclusie gekomen dat ik blijkbaar al een MA2600 heb
Blijkbaar ben ik niet ver van de oplossing van het probleem en hoef ik dus alleen te zorgen dat de MA2600 voeding krijgt door pinnetjes 15 en 16 met elkaar te verbinden.
Het enige wat ik nog wil weten, is van welke connector dat de pinnetjes 15 en 16 zijn en waar ik die draden het beste/ gemakkelijkste kan doorverbinden.
Opties die ik nu zie:
- binnenin PC5200
- Kabel aan zijde van PC5200
- Kabel aan zijde van MA2600
- MA2600
Gr. Rob
- binnenin PC5200
- MA2600
Gr. Rob
Als je enige handigheid hebt met (fijn)solderen is de simpelste oplossing de 15 en 16 in de PC 5200 aan elkaar te solderen.
Uiteraard kun je ook de monitorkabel openpellen en daar de 15 en 16 doorverbinden, zó heeft Gene het opgelost.
Persoonlijk geef ik dan de voorkeur aan de doorverbinding ín de PC 5200.
En je kunt ook de MA 2600 openmaken en dáár die doorverbinding maken. Zó doet VDO-Service het als ze de aanpassing maken. Er moet dan wel een spoortje onderbroken worden.
Weergaves: 630
Weergaves: 924
Weergaves: 842
Weergaves: 736
Weergaves: 862
Weergaves: 636
Weergaves: 945
