[INFO] CDC-A03 - 10 CD wisselaar
Blaupunkt CDC A03 - 10 CD wisselaar
Ten disc CD autochanger, compatible with any DMS equipped Blaupunkt radio
Can be horizontally, 45 degree or vertically mounted
Easy to operate with a high resistance to vibration
Easy installation with single 5.0m connector cable (included)
Functions available
  • Disc / Track up/down
    Track scan
    Cue / Review
    Disc scan
    Disc Naming (*)
    Track Programme Memory (*)
    Track / CD mix (*)
    (* depending on head unit)
CD-R media compatible
1-bit delta / sigma-DAC. 8 times oversampling
Frequency response: 5 - 20,000 Hz (-0.1dB)
Crosstalk attenuation: 85dB typ.
Total Harmonic Distortion: 0.005% typ.
Signal to Noise ratio: 100dB (A)
Will play quality CD-R, but not CD-R/W media
Approx. dimensions W245mm x H85mm x D176mm
Rapid CD selection (approx 8 secs)
Complete with one CD magazine, 5.0m connecting cable & full fitting / Operating instructions
  • probleem RNS510 wisselaar
    Weergaves: 713
    Weergaves: 949
  • Cd wisselaar werkt niet
    Weergaves: 470
    Weergaves: 699
