ms5000 language and maps
VR6
Bericht door VR6 »
where i can find ENGLISH language for this navi. ? my navi is on FR lang. :(
and where can find maps for my country ( BOSNIA AND HERZEGOVINA ) :)
To install the English language you will need the appropiate System Software disc. The latest edition is MO5076
With regard to map material you will have to change to another computer while Bosnia Herzogowina is not yet covered by neither Navteq nor Tele Atlas for this relatively old MS5000 system.
Newer systems have a very limited coverage of some parts of your country
The Engish Language can be loaded through the System CD MO 5076.
For your system, Bosnia-Herzegovina is not yet available. It can be expected on a new Navteq release, as for the MS 5200 and the Supercode systems this is already available.
Regards,
VR6
Bericht door VR6 »
i have mo5076 , how i can load , do u can help me ? :(
Go to the Menu, and look for the Languages.
Being there, you say yes to changing the language, and then the system requires the "Language CD"
Then put in the MO 5076 and select the proper language.
This is how it works approximately, it's a long time ago I did it the last time, so you may have to adapt it a little bit.
Succes :wink:
Regards,
VR6
Bericht door VR6 »
i will try , but yesterday i try method like this and cant :S dunno why :\ i have update mo5076 and my navi is upgraded on 7.6
The present situation is that your system has loaded 2 languages, French and....? The last apparently is not English.
If you wish to change one of these two languages, you have to "delete" one of them, and replace it by another from the "language CD", which in this case is the MO 5076.
Regards,
VR6
Bericht door VR6 »
ok , i will try with delete , my lang on navi. is france 2x
how i can delete , with what key or ?
Do you have the manual of the MS 5000?
On page 28 the procedure is described, can you find that?
If not, I will scan it and post it here.
Regards,
VR6
Bericht door VR6 »
i change lang. 2 english , only now need maps :(
Pleased to read that you succeeded in changing the language :D
And yes, I appreciate that you are waiting for the maps of your country and region. Hopefully they will be available in the second half of this year.
Regards,
VR6
Bericht door VR6 »
i w8 i w8 i w8 :)
+ for u :)
    Weergaves: 29284
  • VDO / Mark III navigation system retrofit kit - change language problem
    door glm2006ITALY » 07 okt 2017 22:25 » in Vaste VDO-Dayton systemen
    Weergaves: 664
    Weergaves: 965
  • Navigatieaanwijzingen van Google Maps op 8220
    door Piet22 » 06 jul 2017 20:00 » in Kenwood
    Weergaves: 580
    Weergaves: 742
    Weergaves: 752
