[INFO] XAV-7W
[INFO] XAV-7W
Sony XAV-7W
Technische specificaties :
Specificaties kunnen per land verschillen
Monitor
Motordriven Flip out Colour LC Display
System: TFT aktive matrix
Screen aspect 16 : 9
Screen diagonal (inch / mm) 7 inch / 177 mm
Screen size (WxH) 155.5x87.7 mm
Resolution: Number of picture segment 336960
Dimmer: Manual / Auto
Integrated sensor for IR-Commander
Radio
Tuner / ABC (Automatic Bandwidth Control) SSIR-EXA
Station Presets: FM / MW / LW / SW 18 / 6 / 6 / -
BTM (Best Tuning Memory)
RDS EON
Changer Control
Changer Control: CD / MD
CD Custom File Control: Disc Memo / Bank
Display of CD Text
List Function: CD / MD
Title Scroll: CD Text / MD
Repeat / Shuffle
Amplifier
Output Power (DIN 45324, 4 ohm) 4x 25 W
Max. Output Power (1kHz, 4 ohm) 4x 45 W
Dynamic Soundstage Organizer: DSO II
EQ-7 (7 Band Equalizer)
Separate Bass, Treble Control
Loudness
Pre-amp Output: Front / Rear (HPF)
Sub Volume Control
Signal Input / Output
Colour system: Video In PAL, NTSC
Audio/Video Input (RCA) 2x
Audio/Video Output (RCA) 1x
Other
TV Control (1)
Front Panel Display : Segment
Key Illumination : Amber, Green switchable red
Safety Commander Interface: 3.5 mm jack
Sensor for IR Commander
Security Code
Integrated Clock: 24h
Telephone Attenuator
ISO Connector : supplied Adaptor
Supplied Adaptor Cable (radio / car harness) 16pin / ISO
Installation Angle +/- 15o
Current drain approx. 10 A
Dimensions (WxHxD in mm) approx. 178x50x186.2
    Weergaves: 696
