Ander opstart scherm voor 9260bt
xpatje
Weet iemand hoe je de opstart afbeelding kunt verranderen aub?
J.Sparrow
Re: Ander opstart scherm voor 9260bt
Helaas niet in het Nederlands, maar daar kom je wel uit.
Het lukt echt niet zonder photoshop ivm de speciale instellingen voor de BMP-file!
Image formatting information
1) File Type needs to be Bit Map
2) Pixel Size should be 800 * 480.
3) You need to use a dedicated image processing application such as Photoshop in order to be able to make the right settings and save in the correct format.
4) Save as 16 bit Full Color BMP and the setting of RGB of R5,G6,B5 is very important
5) Windows Applications like Paint cannot be used to make the BMP as the settings for the RGB and picture crushing cannot be done with that application.
Before entering the setup mode, save your settings from the SETUP MEMORY option. Select TOOLS, SYSTEM, SETUP MEMORY. Select YES, MEMORY and confirm that you want to write to the memory. This is also detailed on page 84 of the owners manual. Once the start up screen proceeder is complete, recall your settings from the above options.
To enter setup Mode, Press and hold VOLUME DOWN & SRC buttons, then press RESET button (red triangle).
• Release reset button, and hold VOLUME DOWN & SRC buttons until illumination activates.
• Once the startup screen menu loads, connect the USB Thumb drive containing image file. The files must be in the root directory.
• If you want to change the opening image to your own image (i.e., company logo), Press OEM Image.
The OEM Image will be grayed out till files are seen on USB device.
• If you want to put original KENWOOD opening back, press KENWOOD image.
• Select the image you want to use.
• When the image is loaded, select Enter. Once the file writing is complete, hit the RESET button again. The unit should now boot with your new screen. Recall your settings and your done.
xpatje
dank u.
Ma heb toch een vraag.Die afbeelding die ik wil moet op een usb stick en die moet ik aan de "mini" usb kabel kopelen?(aan de achterkant van de dnx9260bt zijn 2 usb uitgangen,een voor de muziek mee aftespelen en een om in de software van de kenwood te geraken, voor dat laatste is da een "mini" usb uitgang)
J.Sparrow
Nee gewoon op de normale usb ingang.
Je kan overigens ook Photoshop Elements (trial versie/aantal dagen gratis) gebruiken of
Pix Resizer (gratis).
acjansen
Kan dat ook op de 7260??
______________________________
Honda civic elegance + dnx7260BT
Janloco
acjansen schreef:Kan dat ook op de 7260??
Ik denk het wel. Ik zat net een berichtje te lezen van Radem083 en die heeft in zijn 7260 het logo van Mitsubishi tijdens het opstarten. Dus kennelijk is het mogelijk
J.Sparrow
En ik weet het zeker.Janloco schreef:Ik denk het wel.acjansen schreef:Kan dat ook op de 7260??
vigatie
Ja dat werkt, net gedaan, echter bij het saven van je instellingen worden niet je voorkeurszenders opgeslagen dus die moet je alle 24 weer opnieuw instellen
Weergaves: 665
Weergaves: 635
Weergaves: 803
Weergaves: 1003
Weergaves: 6495
Weergaves: 976
Weergaves: 1334
