update kenwood dnx 5 serie
mario12spydi
Bericht door mario12spydi »
IK HEB HEM WEL GEDOWNLOAD EN UITGEPAKT MAAR KRIJG HEM NIET GEBRAND
Marc Veen
Re: update kenwood dnx 5 serie
Bericht door Marc Veen »
mario12spydi schreef:IK HEB HEM WEL GEDOWNLOAD EN UITGEPAKT MAAR KRIJG HEM NIET GEBRAND
Legaal?
Zie item Ie van het regelement;
"Discussies over illegale kopieën en over kopiëren van kaart materiaal dan wel besturings software zijn niet toegestaan op het forum."
Marc
mario12spydi
JA GEWOON VIA DE LEGALE WEG VAN KENWOOD
Marc Veen
Oke.
Geef even een site/link waar je hem vandaan hebt dan kunnen we meelezen hoe de installatie aanwijzingen zijn.
Gr,
Marc
mario12spydi
Marc Veen schreef:Oke.
Gr,
Marc
GEWOON VIA GARMIN PARTNUMMER 010-00699-00
UPDATES EN DOWNLOADS
Marc Veen
Waar in de onderstaande instructies loop je vast?
Installation Instructions
1.Download the appropriate self-extracting archive file onto your PC.
2.Run the downloaded executable file.
3.Click on Browse and a select temporary location of your choosing to extract the update.
4.Click Unzip to extract the update.
5.Wait for the message that the update was unzipped successfully and close the updater.
6.Insert a burnable CD into your PC.
7.Use CD burning software to create a 'garmin' directory on the CD.
8.Add the files extracted in step #4 to the 'garmin' directory on the CD.
9.Burn the files to the CD and eject the CD from the computer.
10.Turn on the Kenwood Navigation System and press the [NAV] button to switch the display to the navigation system screen.
11.Insert CD into Kenwood Navigation System. If there is already a CD in the drive, temporarily remove it first.
12.Your Kenwood Navigation System will ask if you would like to update software. Answer 'Yes'.
13.The unit will display banner 'Navigation Map Update Start'.
14.The unit will restart several times during the update. The CD will eject before the update is complete. The warning page will display when the update is complete.
15.Do not power off unit while the update is in progress. When finished you can verify the update by checking the version number in Menu->Settings->About->Software.
mario12spydi
[Quote = "Marc Veen"] Waar in de onderstaande Instructies lus JE overgrote?
Installatie-instructies
1.Download de juiste self-extracting archiefbestand op uw PC.
2.Run het gedownloade uitvoerbare bestand.
3.Klik op Bladeren en selecteert u de tijdelijke locatie van uw keuze om de update uit te pakken.
4.Click Unzip om de update uit te pakken.
5.Wait voor het bericht dat de update succesvol was uitgepakt en sluit de updater.
6.Insert een brandbare cd in uw pc.
7.Use het branden van cd-software om een 'Garmin' Maak de map op de cd.
8.Add de bestanden uitgepakt in stap # 4 van de 'Garmin' directory op de cd.
9.Burn de bestanden naar de CD en de CD uit de computer.
10.Turn over de Kenwood navigatiesysteem en druk op de [NAV] knop om de display te veranderen naar het navigatiesysteem scherm.
7-8 EN 9 HIS STAAT WEL OP DE PC UITGEPAKT MAAR HET BRANDEN LUKT NIET EN ALS IK HEM MET DVD DECRYPTER BRAND KRIJG IK CD ERROR IN DE KENWOOD
11.Insert cd in Kenwood navigatiesysteem. Als er al een CD in de drive, tijdelijk te verwijderen voor het eerst.
12.Your Kenwood navigatiesysteem zal vragen of u wilt software-update. Antwoord 'Yes'.
13.Het apparaat banner 'display Navigation Map Update Start'.
14.Het apparaat zal opnieuw meerdere malen tijdens de update. De CD wordt uitgeworpen voordat de update is voltooid. De waarschuwing pagina wordt weergegeven wanneer de update voltooid is.
15.Do niet uitschakelen apparaat terwijl de update bezig is. Wanneer u klaar bent kunt u de update door controle van het versienummer in Menu-> Instellingen-> Over-> Software. [/ I] [/ quote]
Marc Veen
mario12spydi schreef:MAAR HET BRANDEN LUKT NIET EN ALS IK HEM MET DVD DECRYPTER BRAND KRIJG IK CD ERROR IN DE KENWOOD
Wees er zeker van dat je hem op de laagst mogelijke snelheid brandt. Dus niet op 48x maar op 8x of nog lager.
Hoe lager de snelheid des te minder kans op fouten.
Marc
mario12spydi
Marc
IK HEB HEM ZELFS OP 1 GEBRAND IK ZAL WEL IETS FOUT DOEN MAAR WAT MISSCHIEN DAT ER STRAKS IEMAND MET EEN OPLOSSING KOMT GA WEER VERDER STOEIEN ALVAST BEDANKT
Marc Veen
mario12spydi schreef:DVD DECRYPTER
Ik heb even gekeken wat dit voor een programma is.
http://en.wikipedia.org/wiki/DVD_Decrypter
Maar weet je zeker dat je hiermee CD's kan branden?
Marc
mario12spydi
Marc
JA DAT KAN WEL IK HEB ER NU EEN EEN IMAGE VAN GEMAAKT DUS FF KIJKEN WAT DAT WORDT OF HAT JIJ NOG EEN SUGGESTIE????
Marc Veen
mario12spydi schreef: OF HAT JIJ NOG EEN SUGGESTIE????
Misschien dat je een andere brandprogramma kan proberen, Nero bijv.
Marc
mario12spydi
Marc
nou het is me gelukt eerst een image ervan gemaakt en toen op snelheid 4 gebrand ieder geval bedankt voor ieder geval bedankt voor de moeite groetjes mario
Bericht door Higgy »
Ah, da's mooi. En je hebt tevens je Caps-Lock toets gevonden zie ik :-)
  • update voor een DNX-7200
    Weergaves: 1055
    Weergaves: 816
    Weergaves: 1480
    Weergaves: 803
    Weergaves: 1102
    Weergaves: 980
  • Kenwood DNX5160BTS
    Weergaves: 695
Terug naar “Kenwood”
