CF kaarten 7941/7944/7945/7949: wel backuppen mogelijk!
Jivemen
Bericht door Jivemen »
Ok Bey Mach-m
I have some news about the 4GB story.
Take the 4GB Sandisk and make a partition only 99% from the disk, then look in the orginal 2gb in the nonpartition space 1st sector and you must write the same sentence in the 4gb, and it works.
Somebody can test this story ? :)
Mazda Tribute 3L V6 met Becker Traffic pro 7949
Lomax
Bericht door Lomax »
@Jivemen
From where did you get this advice ? Is this only a suggestion or have someone tried it ?
If someone could tell me how to partitionate only 99 %, i would go out next week to buy a 4gb card to try.
mash.m
Bericht door mash.m »
sorry to all people that wrote me a pm: I CAN´T ANSWER THEM CAUSE THE ADMIN HAS DISABLE IT !!!
@jivemen
i don´t write anything more in this forum, cause it will be against the copyright laws ! you and the other people here in this forum should talk in a chatroom or via email about this !
luise
ok mash.m
Bericht door luise »
please send me message in my email.
thanks
Edit Mod: Adres verwijderd.
Geen correspondentie over illegale zaken via het forum. Lees er het Reglement op na :idea: :!: :!:
Laat dit een laatste waarschuwing zijn, anders gaat dit draadje op slot :twisted:
mash.m schreef:sorry to all people that wrote me a pm: I CAN´T ANSWER THEM CAUSE THE ADMIN HAS DISABLE IT !!!
@jivemen
This Forum contains presently 34103 articles posted by 8685 users, which are NOT against the copyright laws.
So feel free to post normal messages, only those which contains illegal aspects or links (see the Reglement) will be removed.
Regards,
CascadeUser
Bericht door CascadeUser »
TurboSoosy schreef:I tried to copy the original to an SanDisk Ultra II 2GB. But it dosnt work. The card was not accepted by the nav-system.
Should i de-/select some options in the clone-windows of winhex?
Same Problem here... I tried to copy my original CF card (Traffic Pro/Cascade Version 2.0) to a SanDisk ULTRA II 2GB. I´ve used WinHex 14.0. At first I get a image of the original card and after that I recover the image to my new CF card. I don´t chance any option. Why doesn´t it work? What can I do for getting the copy running?
TurboSoosy schreef:The Original is an SDCFJ-2048 and the copy is a SDCFH-2048. I think thats the problem....
Is this really important? How I get this information?
Thanks for your help.
champ1
Bericht door champ1 »
Vorweg erst mal Hallo und sorry aber ich kann nur in deutsch schreiben und hoffe einer übersetzt für mich.
Nachdem ich mich jetzt Nächtelang mit der Problematik auseinandergesetzt habe , habe ich die Lösung gefunden.
Problem der CF Karten ist die Formatierung die irgendwie mit Win95 Fat16 LBA gemacht wurde aber alle CF Karten die man kauft haben Fat16 Big. Ich habe alles versucht und gegen Ende bin ich auf das Programm Disktool gestossen. Dieses erstellt ein Image der CF Karte auf die Festplatte und anschliessend schreibt es das Image wieder auf die CF Karte. Jeder Vorgang dauert ungefähr 90 Minuten aber danach lief bei mir jede CF Karte 2GB im Navi . So kann man sich eine Sicherheitskopie der NAvisoft erstellen. HAbe leider keine 4 GB Karte um zu sehen ob diese dann auch laufen.
MFG Champ
PS: Die Anmeldung mit dem Bestätigungscode ist echt nervig weil man nicht immer erkennen kann was dort genau steht.
papymouzot
Bericht door papymouzot »
Goedendag, spreek ik niet Nederlands en ik zoek een backup van CF kaart 3.01 voor mijn Becker Cascade
kunt u me het verzenden per e-mail?
bedankt
Je mag dan misschien wat moeite hebben met het Nederlands, maar één ding is duidelijk: wat je vraagt is NIET toegestaan, dit is illegaal. :twisted:
Zie verder het Reglement.
papymouzot
In Frankrijk, is het wettelijk een beschermingskopie, één te doen..
Ik heb mijn kaart beschadigd en ik kan niet meer gebruiken mijn autoradio. Ik vraag hulp
Ook in Frankrijk is het NIET toegestaan achteraf van iemand een "back-up" te vragen als je eigen kaart om een of andere reden verloren is gegaan.
Dit is dus ook hier TABOE.
passatvw
Bericht door passatvw »
Hallo dan!
Ik heb het eens geprobeerd, maar dat werkt echt niet, is het wel iemand gelukt dan?
Ik dacht, mooi kan je de orginele lekker thuis laten en draai je verder op de clone.
Alleen de adressen die je genavigeerd hebt (alleen de 2 laatste) op de orginele kaart doet het.
En wat wel klopt is dat je FAT16 niet verder kan gebruiken dan 2GB.
Dus groter kan al helemaal niet.
Ik heb de 7944 van Becker, en hij slikt hem niet.
Als er toch iemand het gelukt is, moet die mij maar eens vertellen hoe die dat geflikt hebt.
Petje af voor Becker dat ze het zo moeilijk hebben gemaakt (dat dan wel weer) :worshippy:
mvg
Passatvw
Je laatste 3 postings gaan over kopiëren van SW.
Lees nog eens even artikel Ie van het Reglement rules.php waarvoor je bij je aanmelding getekend hebt :idea:
passatvw
Umm, nu ben ik een beetje verward, een backup maken MAG niet, misschien zie ik het verkeerd, en u mag me best op de vingers tikken als ik wat verkeerds zeg of doe. Maar het is NIET verboden om een backup te maken van je SW.
Het is voor eigen gebruik, ik heb er genoeg centen voor neer geknald,
Dan die reactie die ik op cablerichy doe, heeft er al niets mee temaken.
Hij had een probleem met zijn Becker.
groet,
Passatvw
De discussie is niet of het al-dan-niet mag.
Dit Forum heeft een Reglement gemaakt waaraan leden zich te houden hebben. En in dat Reglement staat dat discussies hierover niet toegestaan zijn op dit forum, zo simpel zit het :idea:
passatvw
JW schreef:De discussie is niet of het al-dan-niet mag.
ok... gooi deze topic dan dicht in archief of laat hem verwijderen door een moderator of site admin.
Dan nog zijn het nog steeds [b[2[/b] reacties/posts die ik over SW heb gedaan.
(tja je wilt niet hebben dat ik deze discussie over PM of e-mail doe, gezien je sign, dus dan maar een topic vervuilen)
:idea:
No offense, het gaat er om dat op dit forum al eindeloze en daarmee oeverloze discussies over al-dan-niet toegestane kopieën hebben plaats gevonden. En dat heeft geleid tot dat bewuste artikel in het Reglement.
Interessant is het om ook nog even viewtopic.php?t=9324 te lezen, daar gaat het over SW met copy-protect. En daar vallen de huidige Beckers zeker ook onder.
andre.l
Bericht door andre.l »
Ik heb 2x een cascade 1x met 4.0 en had 1x 3.7. Nu heb ik met de laatste winhex ook een 2e 4.0 kunnen maken op de originele kaart.
nu is alleen mijn vraag, zit de A73 niet in de 4.0 ?
De database van de Cascade 4.0 is van 2007 Q2
Dat daarbij de A73 is opgenomen is uitgesloten
andre.l
Gerritje schreef:De database van de Cascade 4.0 is van 2007 Q2
Waarom komen van dit systeem eigenlijk geen updates ?
Net 13 april met Becker Duitsland gebeld, ze zeggen eind dit jaar 2010 dus, komt een update.
Heel goed mogelijk, zelfs meer dan waarschijnlijk, dat er helemaal geen updates meer komen,
De versie 4.0 die eind 2007 op de markt zou zijn gekomen, zoals ook destijds door Becker was aangekondigd, is door allerlei vertragingen pas eind 2008 op de markt gebracht. Met als gevolg dat alle gegevens ook al een jaar ouder waren. Was ook lekker goedkoop voor Becker. Oude gegevens kosten veel minder aan licentie!
Ik meenda dat er bepaalde disputen waren over onderdelen van de software ivm licentie-beperkingen.
Bij de Cascade/Indianapolis gaat het niet alleen over de navigatiesoftware maar ook over de BT functionaliteit
    Weergaves: 1367
    Weergaves: 701
    Weergaves: 708
    Weergaves: 1333
  • Kaarten Q4--2015
    door DigiWalker » 17 dec 2015 21:02 » in Navigon
    Weergaves: 1869
  • nieuwe kaarten 965.xxxx.
    Weergaves: 1075
  • kaarten ver. 970.xxxx
    door japie57 » 19 mei 2016 21:53 » in TomTom
    Weergaves: 1556
