dit ook nog gevonden en ook nog ff gedaan, dus zonder de motor aan te zetten.
en wat denk je ?
Upgrading the navigation CD-ROM reader software
takes about 5 minutes.
If the CD-ROM is ejected during installation, carefully
clean it, then reinsert it into the reader. The system will
restart automatically.
1 Switch on the ignition without starting the engine.
2 Select OK on the Navigation system welcome
screen.
3 Select Navigation from the main menu.
4 Eject the map CD-ROM by pressing the Eject
button on the front of the CD-ROM reader. See the
Navigation Assistance Technical Note for the
location of the parts.
5 Insert the CD-ROM labelled Languages CD -
Nav5 All Versions.
6 Once the CD-ROM has been detected (which
takes a few seconds), the system asks: "Install
software?".
7 Select Yes if the current version displayed and
new version differ.
8 A wait message is then displayed for about
15 seconds before the screen goes black.
9 After about 10 seconds, the system indicates it will
update the software ("The installation program
will update your system").
10 Wait approximately 2 minutes. A progress bar
appears. It enables you to track the progress of the
software upgrade.
11 Once the upgrade is finished, the system
automatically ejects the "Languages CD - Nav5
All Versions".
12 The system then reboots with a message: "The
system will reboot now".
13 The screen goes black and the RENAULT logo
appears.
14 Next the system displays the "Navigation" menu.
15 The system upgrade is now completed. Insert the
map CD-ROM into the reader.
WARNING
Do not switch off the ignition during this operation or
the navigation system will become unusable.
Note:
If both versions are identical, select No: the system
already has the new software. The system then
automatically ejects the Languages CD - Nav5 All
Versions. Insert the map CD-ROM into the reader.
Note:
The "progress bar" may remain at 100% for a few
seconds. This is normal system operation.
Note:
The "Languages CD - Nav5 All Versions" must be
used instead of the old one to install new languages
into the system.
noppes nada
mij maar lek
