[INFO] TME-M750 - 6.5" Wide Screen LCD Color Monitor
Overzicht en handleidingen van Alpine Navigatie systemen
Alpine TME M750 - 6.5" Wide Screen LCD Color Monitor
Features :
Monitor :
- 6.50 Super High Density Wide Screen Display
- 4 Viewing Options Normal/Wide/Zoom/Cinema
- Dedicated RGB Navigation Input
- Dedicated RGB TV Tuner Input
- 2 AUX Audio/Video Inputs
- Built-In Amplifier & Speaker
- Headphone Output
- Sorce Selection From Front Panel
- Front Panel Adjustments for:
- Brightness
- Color
- Tint
- Dimmer
- Dimmer Level
- Display Mode
- Sound Out
- Selectable Dimmer Control
- Infrared Remote Control Repeter on Front Panel
Specifications :
Monitor :
- Dimensions (WxHxD)in- 70 x 4-7/80 x 1-1/40
- Number of Picture Elements- 336,960pcs. (1,440 x234 dots)
- Light Source- Internal Optical System (U-Type Cold Cathode Fluorescent Tube)
- Weight- 470 grams
- Screen Size- 6.50 Diagonal (16:9)
- Display System- Low Reflection Rear Projection Type TN Liquid Crystal Panel
- Drive System- Active Matrix Drive (Normally White Display)
- Dimensions (WxHxD)mm- 178mm x 124.8mm x 32.1mm
AV Interface Unit :
- Dimensions (WxHxD)- 196.2x119.9x28.5mm
- Weight- 670g
    Weergaves: 697
    Weergaves: 539
    Weergaves: 495
    Weergaves: 601
