[INFO] MM5600 - Kleuren monitor 6.5"
VDO MM 5600
Features :
6.5" Slide-Out Colour Monitor with Integrated Loudspeaker
1 DIN sized chassis
16:9 Widescreen Format
Antiglare Coating
RGB Interface
CVBS (Composite Video Burst Signal)
IR Sensor
Auto power-on after fold-up
Screen Security Logic (automatic reload when screen will not be folded up / after fold-down)
Ambient Light Sensor
Automatic Display Brightness Control
Max brightness: 400 cd/qm
Adjustments via buttons on front
Automatic 50/60 Hz switch
Automatic PAL/NTSC switch
Sliding time for screen: < 2 sec.
Resolution: 400 x 234 pixels
Operating voltage: 9.8V - 15.6V, negative ground
Current consumption: typ. 1.5 A
Dimensions (Front): 182 x 118 x 40 mm
Dimensions (Box): 175 x 145 x 50 mm
Weight: 900 g
  • Betekenigs Kleuren in nuvi
    door Hermada » 08 aug 2019 23:06 » in Garmin
    Weergaves: 420
    Weergaves: 434
    Weergaves: 570
